搜索 | 用户支持
详细了解
address book export not visible in menu
  • 1 个回答
  • 1 人有此问题
  • 2 次查看
  • 最后回复者为 Toad-Hall
Hello, I want to transfer my address book to another computer, but in the Tools Menu, there is no Export option, only Import. How can I retrieve the Export function?
已附加屏幕截图
所有回复 (1)
Your image looks very odd. That toolbar does not relate to the 'Address Book', it is a toolbar for emails and folders.
Also you have the Personal Address Book showing in a tab instead of a new window, so it does not have the correct toolbar. Are you using some addon for this ?
From the image you posted ; Tools > Address Book should open the Address Book in it's own window with it's own correct Toolbar. Then 'Tools' > Export'
由Toad-Hall于修改
